battery relocation question
RS12Turbo
On battery relocation.......the little connector with 3 wires that connects to the + battery terminal.....in this "how 2" guide, it says to simply cut it off, and run wires with ring terminals to the starter post where the + battery cable hooks up to, and connect them there. Has anyonetried or had any issues doing this? Is there a need to put in 3 in-line fuses to be on the safe side? What exactly is that connector....fusable link or something?Here's the linky http://www.projectautox.com/battery_relocation.php
Thanks for any help
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
When I did it on a friend's car the other day, we just ran a wire from the back seat (battery is on the floor behind driver) to the engine bay and hooked it up to the wires that would otherwise go to the battery. The battery has the positive wire on an 80A fuse 3" from the terminal. It works just fine and only cost us about $15 in 2GA wire from Lowes.
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
r34 gtr wrote:When I did it on a friend's car the other day, we just ran a wire from the back seat (battery is on the floor behind driver) to the engine bay and hooked it up to the wires that would otherwise go to the battery. The battery has the positive wire on an 80A fuse 3" from the terminal. It works just fine and only cost us about $15 in 2GA wire from Lowes.
same here...but ummm whats the right amperage for CB??...i hear 100,120,80, and etc...
RS12Turbo
How about the connector....
Is it safe to just cut it off, and extend the wires to the starter post, like in the above link?
r34 gtr
That looks fine man.
Rin5
r34 gtr wrote:That looks fine man.
serious???
you can just cut that piece off and extend all the wires on it onto the starter and hook the + wire of the battery reloc onto the starter post as well??
r34 gtr
I mean, the guy obviously did it and there are no pictures of the car on fire or anything. Man I would just run a cable to those two and tuck them behind the battery tray and not deal with the starter. I have done it the other way a few times, but never with the starter.
On the other hand, it wouldn't be a published writeup if it was wrong.
RS12Turbo
so what is that connector....just a connector, or some kind of fusible link or something.
r34 gtr
Don't know, don't care. I don't have mine anymore and my battery is still under the hood.
bentvalves
Car: 89 Silvia K's
Tim, could you possibly when you get a chance of course post some pictures of yourself hammered again.
thanks
Greg
ilovecoupes
there is no fusible link or built in resistance, in the red box.
I simply bolted the copper lead of the red box, to the batter's positive pole. Then extended the white wires. I also but a fuse in for the accessories.
If that makes sense.
r34 gtr
I can do you one better, but I need to find a devious way to transfer them from my phone to my laptop first.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
r34 gtr wrote:I can do you one better, but I need to find a devious way to transfer them from my phone to my laptop first.
RS12Turbo
I cut the plug off and connected the 3 wires to the starter post......I'll see what happens tomorrow once i re-install the battery
Rin5
.....soo uhhh what happened? did it blow up?
r34 gtr
6:22 am? do you sleep?
Rin5
occasionally.
ilovecoupes
RS12Turbo wrote:I cut the plug off and connected the 3 wires to the starter post......I'll see what happens tomorrow once i re-install the battery
woah woah.... those three white wires need to go to the positive side of the battery. those wires power your fuel pump/ interior/ exterior/ accessories.
RS12Turbo
Day and a dollar to late....I just put in a new red top, and the car fired right up....fuel pump sounds normal, exterior and interior lights/ accessories all work fine. As I was attaching the 3 wires to the starter post, I've come to the conclusion that it doesn't matter if those 3 wires are hooked up to the battery itself, or the starter post, which the other end of the + battery cable hooks up to.....either way it's hooked up to the + side of the battery......am I right???
r34 gtr
That would be correct.
Rin5
like the guy said with the pee on honda sig said...the starter post pretty much acts as a linking node for 3 wires <==> battery (+)
