onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Aug 04, 2006 8:25 am
don't drive that car. you're gonna blow up in a ball of fire.
That last picture worries me a lot - you have positive power exposed to near metal (which is negative) and also near fuel...
You also have no fuse/circuit breaker or anything in between. If something sparks & the wire catches on fire, you're dead.
I don't like how the ground wire is down by the frame either, that could rust/corrode realllly easily. but if that works, i guess it's fine...
I hope that battery is in a battery box back there...
anyway, first things first:
Put the system back to stock. put the battery where it's suppose to be, hook up the wiring, jump start the car, and see how everything is.
If your battery is already reading 8volts, it could be toast, so you will probably need a new one anyway.
The alternator may also be bad, but the best way to check is to put everything back to the way it was.
And when you relocate your battery again, make it SAFER!
Here's a slightly safer way (not the best way, but one way - it's been modified since then):
DIY Battery Relocation
I take no responsibility for any damage/death that may occur from following the above instructions...
