Aus94Q45 »
https://forums.nicoclub.com/aus94q45-u136.html
Wed Apr 23, 2003 5:31 am
Oh, also, better rig some type of drain on the battery box out to the bottom of the car. Weeped or spilled acid will eat every thing in its path! One other thought has to do with the gas tank located in the trunk. Because the rear panel is not air tight and gas fumes could leak out of the hoses or pump, I may hesitate to locate the battery in the closed compartment. Any fume leaks and a spark from the battery and BOOM! That high octane stuff we use is pretty hot. As I am writing this, I am leaning away from the trunk relocation. Also, if that happened, Nissan would not be liable for any injuries or death based on your modification of the system.
