e_c »
https://forums.nicoclub.com/e-c-u14217.html
Thu Feb 22, 2007 10:26 am
1 what size cable did you run2 you should have a fuse or circuit breaker about 1 foot away from the battery
sounds like 1 the cable isnt a big enough gauge, or 2 your alternator/battery may be going bad... i have 4 gauge wire and it works fine, but when i do it again i will probably use 2 gauge, you can go to a parts store and most will check your electrical system for free to see if your alternator or battery are bad
