naed240sx wrote:
Something tells me that engines operate at a slightly higher temperature than a sunny summer day. Im guessing that your wire will still last for awhile, but just saying be careful, and watch for signs of it corroding.
OK. As an electrician, the wire that Kenrik ran will do just fine. If you have any worries about it just wrap it in the high temperature plastic wrapping everyone uses aroung all wires in the engine bay. Also, AWG #2 wire, like what Kenrik used, is good for 250-300 AC amps. Which in no way is higher then what your starter is pulling (in DC). #2 wire like that is made to handle HIGH heats considering the amount of amps that it can handle.Kenrik, don't worry about your wire. ALSO, I hate to say it but, the best thing to use to hook up your old wires to the new wire is to use a non-fuseable wire block. Just get one to handle your input wire and your output wires. Also, that last time I checked, you don't need a fuse inbetween the battery and the starter. If you did everything correctly, you should have no problems. And if you are gonna use one, then get atleast a 200amp'er. Just my 2 cents.
