Summit Racing Kit: $51.26 after shipping.The kit was well and good, looked like it should have everything I needed, and kind of did. First, I noticed it required holes to be drilled. Having a drill, but no bits, I had to go and get.......
SKIL Drill Bit Set: $15.95A good thing to have no doubt, so I consider this a worthy investment. However, upon routing cable I found that the stock positive cable end has 2 leads going into one battery terminal. How in the world will I connect two roughly 8 gauge lines into one 2 gauge line? You'll buy a.......
Rockford Fosgate Terminal Block: $35.95I probably could have jury-rigged the same thing for cheaper, but I'm getting tired of re-doing jury rigged jobs. Also, it would have been cheaper if I'd ordered it online, but I was in something of a hurry........which leads us to........
Hospital Bill: $1236.95You know those little annoying sealed plastic cases stuff come in? Well smart me decided to try to open one with a pair of scissors, and while trying to force a dull blade through the resilient plastic.....jammed the broad blade of the scissors halfway through my other wrist. You thought those spurting blood things in the movies were exaggeration? Not so!!!
I immediately tied a rubber glove around my arm, cinched it WAY tight, tied a towel around my still bleeding profusely wrist, and drove myself to the ER, in my five speed S13. A blood-soaked interior, and five minutes later, I was rushed into the ER, cauterized, anesthetized, and sewn up.
All in all, $1400 to move the battery to the hatch? Not worth it to me, maybe some of you can do it cheaper though
