coupe4me wrote:Weight that you can move from the front to the back is almost always better for f/r weight ratio. (In this case especially) Also, if you plan on using a turbo'd motor with a fmic, you have to move it. The battery would severly interfere with the plumbing. But this is all just my opion, take it for what you will.
coupe4me wrote: Also, if you plan on using a turbo'd motor with a fmic, you have to move it. The battery would severly interfere with the plumbing. But this is all just my opion, take it for what you will.
