Battery Recommendation?
Stu Segal
Car: G35 Coupe, Silver, Aero / '06 C6 6.0L
I picked up my G35 Coupe in January 2003, which means my original battery is now 5+ years old.
I'm thinking I should, proactively, replace it. Any recommendations for what kind of battery I should replace it with?
Thanks. . . . .Stu
joe603
Car: 2014 Durango R/T
If you plan on upgrading the stereo get an optima yellow top. Red top for normal, OEM, conditions.
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
If you made 5 years on the original battery you've done well. I've always had good luck with Interstate Batteries, you might give them a look while shopping around for your new one.
http://www.interstatebatteries...&js=1
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Just don't go cheap and you should be fine. Plan on spending $100.
TJMaxx98
Car: 2004 G35 Coupe / 2008 FX 35
Hi Stu,
I have been using Gold-Duralast Batteries for a long time and never had 1 single issue. It's about 100 dollars for the G35. I just replaced the battery in my wife's I30 with the Duralast Gold, the car turns over much faster and the lights shine brighter.
Hope that helps...
wrems
Car: 2004 G35 Sedan 6MT
If you have a Costco membership I would definitely look there too. I know they carry batteries but not exactly sure which brand, they tend to re-badge everything with Kirkland Signature. However, they usually have descent quality for the price...
I have not personally had any experience with their batteries. If anyone has I'd be curious to know their experience and if they know which batteries are they carrying. I'm most likely going to be in the market for a new battery sooner rather than later
goneracin
Car: 2004 G35X Sedan 1990 Mustang conv.
Anything but optima batteries. I have used them in many different applications and they have only proven to disappoint me over time. I've put them in daily driven cars and trucks, my mustang which was only driven once a month and was kept on a trickle charger, and on forklifts which were started over a dozen times a day every day. Every one of these batteries fell short to a conventional battery. One died with less than a year of use.
Buy a mid to upper end conventional battery.
Kevin
joe603
I had a red top Optima that lasted 6 years on my firebird....have 2 years on my yellow top in my G. Never heard anything but good things for Optima batts..
telcoman
Stu Segal wrote:I picked up my G35 Coupe in January 2003, which means my original battery is now 5+ years old.
Thanks. . . . .Stu
Stu
Consider yourself lucky to get 5 years out of a battery. I've had good luck over the years with Sears Diehard Gold and Interstate has a good reputation as well. I tried a search once for the CCA rating of the Infiniti battery in my G but was unable to locate it. I would also get a price from your local Infiniti parts department. Whatever you decide, go for the best battery with the highest CCA rating you can find.
Telcoman
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I'm kind of surprised. I went with the Duralast Gold for my I30 and I love it, the only weird thing was that my idle went down really low (500 RPMs vs the 650 it's supposed to be at).
Anyways, I think I paid around $70 for that. Why would the same type of battery for the G35 be $30 more?
TJMaxx98
Sentientbydesign wrote:I'm kind of surprised. I went with the Duralast Gold for my I30 and I love it, the only weird thing was that my idle went down really low (500 RPMs vs the 650 it's supposed to be at).
Here is the price for the G35 from the autozone website...maybe the G35 needs more power vs the I30? By more power higher = CCAs??
Gold-Duralast / Battery (640 cold cranking Amps)Warranty - 8 YR 35-DLG Price: $82.99 Core: $12.00 Total: $94.99 So it's 82.99 with the core trade in...the Optima Red Battery is 179, is that really worth the extra $$?
Stu Segal
Thanks guys.
Sounds like an Interstate, Optima or Sears DieHard is the way to go.
Sentientbydesign
96 I30 - Sold
I'll check later, but I'm sure my I30 battery was putting out over 700 CCA.
Maybe it's the physical shape of the battery that is making it more expensive. *shrugs*
TJMaxx98
Price could be based on your zip code.
Are the Optima batteries totally maintance free? That would be a plus not having to add water every so often. Also heard they don't weigh as much.
joe603
TJMaxx98 wrote:Price could be based on your zip code.
Yes, they are a sealed unit..."gel-cell". Make sure whatever you get is the JDM style or you will have to modify some things to get it to fit properly.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
When I was checking consumer reports a while back, they liked Napa Legend and Duralast 35DL best. Diehard Gold was third.The Duralast was a CR best buy
C-Kwik
I'd avoid the redtop Optimas. They don't handle full discharges well. 2 or 3 will render the battery pretty much useless. The Deep Cell Optimas (Yellow or Blue) are great so long as you don't have a huge need for high CCA's. Deep Cycles are not designed for maximum CCA's like a starting battery is. However, they are more than sufficient for most people so long as the climate isn't terribly cold. I ran a Bluetop in my first 240 after bad experiences with two redtops. The nice thing about that battery is that since ints a Marine battery, it has the typical automotive posts along with a threaded post. I sued the threaded post as a connection point for some heavy gauge amp wiring so that I wouldn't have to cut up the factory wiring or shove a ring terminal in there somewhere. I carried that same battery over into my second 240sx, and it still worked strong when I traded the car in. The battery had lasted me some 6 years despite many many full discharges. I have a bluetop in the Titan now.
The only negative about the Optimas are that the sizes and terminal configurations tend to be a bit limited so it can be difficult finding a battery that is a good fit.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Optima Yellow top or Duralast Platinum if you plan on upgrading stereo
I opted for the Duralast Platinum, and I love it.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
well I just had to have mine replaced!
Is that something that is covered under warranty?
Well the battery started to leak acid all over the place and i burned my hand!
I went to walmart and had it replaced for 73 bux out the door!
it also has a 3 year warranty!
DJ
telcoman
Tampa G35 Sedan 6MT wrote:well I just had to have mine replaced!
DJ
I'm not sure but I think you should have checked with the dealer first?They might have covered it?
Telcoman
TJMaxx98
It would have been...every car guy loves to hear "pro-rated" Dealership said my battery didn't pass the load test, but since it was still under warrenty it would only be $75 for a new OEM replacement. No thx....got in my car (it started right up) and drove off!!
BTW...the OEM replacement battery is something crazy like 180 dollars!!
wrems
In need of anything at Pepboys? Battery perhaps...
