Battery Question
Two-Fortee
Car: 180sx.
Hey guys, I have a 180sx with a CA18DET in it. I have a FMIC, which unfortunately means there isn't much room for a battery due to its piping. The battery that was in there has recently died on me. The space in which I need the battery fit is 5x7.5 inches. Do you know where I can find a battery of this size? I went to Canadian Tire and they said they have motorcycle batteries but they don't have enough amps to crank over a car engine. How many amps do I need to crank over a ca18det? These motorcycle batteries had about 350, and they were saying I will need around 500 or 600. Can you guys help me out on where to buy a battery for my car? I really don't want to do a trunk relocation.
BACARDI_DWB
http://www.jayracing.com/index...y=USD
I know lots of guys that swear by these. this should work for ya
rovert
Car: 1992 Nissan Silvia
I spent $15 at AutoZone for a plastic battery box and relocation kit. I have seen a lot of people use motorcycle batteries but I like the look and ease of relocating it.
nismoplsr
rovert wrote:I spent $15 at AutoZone for a plastic battery box and relocation kit. I have seen a lot of people use motorcycle batteries but I like the look and ease of relocating it.
Until you go to the drag strip and need an external kill switch that also kills the charging circuit. Then it becomes not so easy.
I have a PC680. Worked great all summer, now not so much, wont even crank the engine. I dont think it is the fact of the lower CCA i believe the battery is just dead. I am still investigating. Will let you guys know when i figure out the problem.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
oddessy makes some nice compact performance batteries. IIRC a company called CPE make a hot billet mount for the battery too.
jt15833
Car: 95' 240SX
ca18detgabby wrote:oddessy makes some nice compact performance batteries. IIRC a company called CPE make a hot billet mount for the battery too.
+1 for the odysseus its what i rock
drifting circles
Car: 240sx
I use a 91 mazda miata battery that works also
float_6969
I use a lawn and garden battery. I have to replace it at the beginning of every winter.
Two-Fortee
Car: 180sx.
float_6969 wrote:I use a lawn and garden battery. I have to replace it at the beginning of every winter.
do u know how many amps it has?
koukis14drift
Car: 97 240
Two-Fortee
Car: 180sx.
koukis14drift wrote:5
Either your an idiot or your just being a d!ck. It takes like 500-800 amps to crank over a car engine....
koukis14drift
Car: 97 240
no i typed 500 and it must have not taken in the two zeros... oops
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
The starter draws about 100-125 amps.
float_6969
Two-Fortee wrote:do u know how many amps it has?
325CCA IIRC.
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
all u need is 330ish CCA for a CA most any lawn garden battery will work, or u can use a battery relocate like i have, and use whatever battery u like. I got a group 35/75 optima red in my trunk. no problems there.
NissanTouge87
Car: 1992 CA18 S13 hatch, 1992 pignose nissan pickup
duralast battery from autozone..i went to the battery section and picked out the smallest battery with normal terminals..works awesome, cranks over my engine like it was a weedwacker..the engine hasnt been running long enough to judge its longetivity...but it has ok reserve time for being a lawnmower batter
rovert
Or you could not drag race your 240? Everybody here with a cheap lawn mower battery has to keep replacing it every year? $15 and I KNOW when I go to start my car I wont have a problem.
float_6969
They always have a one year warranty so I haven't actually had to buy one yet. They just replace it every year.
It helps that I'm friends with the guys down there, and they don't care either.
If I was having to pay for them every year, I'd get an oddessy.
