Battery Question
bolenballa
I bought a shell to put an sr20 in. I need help with battery wirning because i think the positive is missing. Can someone please post a pic of their battery wires and where they go into the fuse box at?
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
S13 or S14 Kouki or Zenki?
bolenballa
its an s13. I just dont know where the positive terminal goes.
bolenballa
Anyone?
Hijacker
Car: '92 240sx Convertible
'94 F-150
The positive harness is attached to the lower engine harness. It'll be the one with the big red plug attached to it. Two smaller plugs attach to it that supply the fusebox.
The negative is a long cable that grounds out on the chassis and then grounds out on the block.
bolenballa
Thanks, So i just need to find the two small plugs that come from under the fusebox that connect to the positive battery wire/terminal on the sr20 lower engine harness?
Hijacker
'94 F-150
correct. they should be small green looking male plugs. I don't have any pictures or service manual screen caps to show you because I'm at work right now
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
bolenballa
Thank you very much.
