Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Nov 04, 2005 8:19 am
I think you may just have too much money. Why do you need an optima? The fact is, you are not drifting, rallying, or the like, you do not need a battery designed for heavy vibration. A good high end normal battery will have 60 cycles in it or so, so you don't need a battery that will need more cycles than that. If you perform proper maintainence then you will get 3-5yrs out of that one. For half the price. Also, good luck on charging an AGM, no, I mean it. Research that one. But if you are insistant on getting that damn redtop you will want a 34 or 35 group, but that may give you a problem fitting it for top height. I would be surprised to find out that they do not make a 24F(R) group, which is what you will need. Don't waste your money on a difficult to deal with AGM, unless you are getting it to clear your intercooler piping.
