Battery problems 08 spec v
Boss1985
Car: 2008 Nissan Sentra SE-R Spec V. Injen CAI, BRM Exhaust
So I'm having problems with the positive terminal on my battery staying connected. The thing doesn't actually lock down, its easily moved up or down off of the battery itself. I have an amplifier in my car and this causes a little bit of play but there seems to be no way to actually tighten it down. I'm about to grab a pair of pliers on pinch the damned thing down. Has anyone found a way to fix this issue or any replacement cables or terminals which go to the conventional nut and bolt method? I call the dealership and they said no such cable exists (cop out?). Thanks again guys!
nametakennow
Car: '06 MINI Cooper S
How does it go on? There's no nut/bolt assembly at all?
If so, wow. That's just flat out boneheaded. I'd try pliers or something to tighten it before I cut it off and put on an adjustable end.
david_mejia9190
Car: 2007 Nissan Sentra 2.0L
yeah i had the same problem with my sentra but its the 2.0still though i think the battery terminals are pretty similarpliers worked fine for me
