mkory »
https://forums.nicoclub.com/mkory-u17964.html
Sat May 07, 2005 4:59 pm
Okay, I tried starting my car while it was in gear (a friend left it that way... wasn't paying attention) and when the starter engauged the flywheel wouldn't allow it to turn. So, in order to start my car I needed the power of 2 batteries (like jumping it). At first I just thought that my battery was no good anymore, so I tried using the one from my mom's Ford Taurus. Little did I know that the terminals were on opposite sides.
I hooked up my ground wire to her positive, and when I touched my positive to her batteries negative terminal, it sparked. I immediately realized the problem, and turned the battery around hooking it up like I should. Now, ALL lights, gauges, and EVERYTHING that needs power isn't getting any. I did find one fuse under the hood that was blown, it was a 75 amp fuse at the top-middle of the underhood fuse box. (I can't remember what it was labeled as and can't check as the car is at my mechanics) This is the only one that I've found so far to be blown. Are there any other fuses or problems that could result from doing this? Anything I need to look out for?
The car is a 1995 240sx. Thanks!
