You can't find ANY grounds? Start by checking that you have a clean connection on the negative terminal. Follow that cable to (I believe) the intake manifold. Check to make sure you have a solid connection there. If everything looks to be okay, but the problem persists, you probably just got unlucky with the battery.johnnyknoxvillej wrote:i got a new 750cca battrery, and checked for grounds but i cant find any i dunno where to go with this
masticatingcow wrote:You can't find ANY grounds? Start by checking that you have a clean connection on the negative terminal. Follow that cable to (I believe) the intake manifold. Check to make sure you have a solid connection there. If everything looks to be okay, but the problem persists, you probably just got unlucky with the battery.
We already know that your 750cca battery reads 420cca. When you measured it, you tapped terminals, right? When you did that, you created a tiny closed circuit that isolates the battery from every other system in the car, right? So how would your accessory circuit come into play? Call up a friend and borrow his or her battery for five minutes. Check the battery and if it reads right, drop it in real quick to see if things improve. If so, no big deal, it's just your particular battery. It happens.johnnyknoxvillej wrote:i grinded down the point where the ground sits, i dont think it is a battery problem because it still starts. I was reading my fsm last night and there is actually a accesory relay im going to see if thats it but i dont think that will amount to much. Any suggestions would be awesomeMATT
No he bought another battery to replace the lesser CCA one.masticatingcow wrote:We already know that your 750cca battery reads 420cca. When you measured it, you tapped terminals, right? When you did that, you created a tiny closed circuit that isolates the battery from every other system in the car, right? So how would your accessory circuit come into play? Call up a friend and borrow his or her battery for five minutes. Check the battery and if it reads right, drop it in real quick to see if things improve. If so, no big deal, it's just your particular battery. It happens.
Thanks for helping in the forum.masticatingcow wrote:
Oops. I thought he was recapping the situation. Mi mal.
