ElementalFiend »
https://forums.nicoclub.com/elementalfiend-u83210.html
Fri Jun 20, 2008 4:36 am
I've got a battery problem I'm trying to sort out.
1991 240sx hatch
Car has been fine for the last 6 months I've had it. One day it was hard to start. This got progressively worse each day after until it was impossible to start. I cleaned the terminals and that worked for a while. It got to the point where I had to clean the terminals every time I wanted to start the car due to corrosion building up so quickly. So I've replaced both terminals and the car started perfectly for a while. Now the problem is happening again, except there is little corrosion on the new terminals, so I no longer believe that was the cause.
Any idea where I should start looking for the source of this problem? It is a pain to clean the terminals every time I need to go somehwere.
Other info:-The battery checks out fine and has been fully charged. The car starts great once I have a solid connection to the battery.-I only replaced the terminals, not the cable (I don't know how).-I'm a newb.
Thanks for any help.
