Dr. Evil »
https://forums.nicoclub.com/dr-evil-u2854.html
Sun Oct 05, 2003 3:21 pm
Take your car to a shop.
Have them test the battery and alternator. If the guy comes out with a voltmeter, he doesn't know what he's doing.
Read the battery. Find the 4 character code on the front/top/side. There are usually 4 characters. The last two are the important ones. One should be a letter, the other a number. The number is the year the battery was made, the letter is the month, meaning.
XXA6 january 1996XXB6 February 1996XXG9 July 1999 etc (the XX are usually manufacturer specific codes). Sometimes it is reversed, the number and letter are first. ACDELCO, INTERSTATE and anything sold at sears all conform to this code, as do most other domestic batteries made after 1970.
If your battery is more than 60 months old, replace it. It is no longer dependable. Holding a charge? maybe. Starting up the car? maybe. Dependable ? NO. You don't want to gamble that when there is an emergency and your car will not start.
If the mechanic has a battery/alternator tester, make sure he knows what he is doing. If he doesn't read your battery and search for the cold-crank amp rating of the battery, he doesn't know what he is doing. Basically, the battery is tested by supplying it with current while applying load (simulating the current drawn for the car's electrical system). The load applied should be aprox 1/2 the cold crank amp rating. If he just twists the knob all the way and holds it, he doesn't know what he's doing, take the car somewhere else.
If the battery test comes up good, he should test the alternator. This test should take at least 10-15 minutes. The car should be running (obviously), and left to idle. If the voltage remains a consistant number, not fluctuating more than 0.1 to 0.3 (max), you are in the clear. Different cars with different alternators have different volt ratings, but the generally accepted "minimum" volt reading for a properly functioning alternator at idle is above 12.9, volts. Different mechanical vocational disciplines state otherwise, but nothing but the best for my customers. Brand NEW Alternator only charging at 12.8? Forget it.
I don't believe I left anything out. A good alternator is ACDelco. They are remag cores, the best thing about it is the warantee, not necesarily the product. Same thing said about their batteries. They offer a great adjustment on a faulty battery. Interstate is the same grade. You wouldn't go wrong with either.
I recommend NIPPON DENSO for all your Japanese OEM needs. Not remags, brand new. I've had cases where we tried 2 different alternators, both nissan OEM from the dealership, and they did not charge properly. Used a NIPPON DENSO, worked like a charm.
Best of luck
