Battery Light!!
Nismo-S14
Car: 1995 Nissan 240sx SE S14 sr20det,1991 Nissan 240sx Coupe
Well i have a 95 240 with a S14 SR and everytime i start the car the battery light and E-Brake light stays on but only for about 3 to 5 miles and then it turns off i just replace the battery and the alternator is still good so please anything will helps thanks!!
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Loose ground wire?
Nismo-S14
Nope i checked all my wiring and this all started after i replace my front main seal my voltage drops to about 11.35 then shoot right back to 13.6
Sil80315
Car: 1991 Nissan 240sx
bad relay?
MikeDombeck
Car: 1995 Nissan 240sx SE S15 SR20DET
i had the same problem. it was the connection to the plug that goes into the alternator and my pisitive terminal to the battery... 2 alternators later i learned that lesson.
Nismo-S14
It was the connection and the postive terminal i just fixed it thank you very much you just save me from buying a new alternator thank you again!!
MikeDombeck
ive got 3 now... lol
