SteveA »
https://forums.nicoclub.com/stevea-u122466.html
Wed Dec 17, 2008 9:44 am
I have searched the current and archived posts on NICO and found similar problems to mine, but none that are exactly the same.
I have a 1997 Q45 that failed to start yesterday. I discovered that the connection to the positive battery terminal was loose and corroded, so I replaced it and the car started right up.
But after I started the car, the battery light came on for about 20 seconds before disappearing. I figured it must be the alternator. So I drove to Kragen to have them test both the battery and alternator. They said that the battery is fully charged and the charging system is working properly. Also, when I turned on the car during this test, the battery light did NOT come on. I figured the battery light I saw when I first replaced the battery cable was a one-time thing - maybe the system resetting itself.
This morning, when I turned on my car, same thing - battery light came on for about 20 seconds, then disappeared. I turned off the car and started it again - this time, the battery light did not stay on.
It was very cold yesterday morning and this morning when first starting the car (high 30s, which is very cold around here). And it seems to be only the first time I start the car each day when I get this symptom.
BTW, I replaced the starter with a brand new OEM part last month.
So, if my battery and alternator are working fine, and my starter is brand new, what could the problem be?
Also, if it was the alternator and Kragen's test was just wrong, wouldn't the battery light stay lit at all times and not just for 20 seconds?
Thanks for the help!
Modified by SteveA at 11:57 AM 12/17/2008
