CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.html
Fri May 23, 2014 3:23 pm
Hey guys, I just finished up my engine swap in my 2001.5 Qx4. Everything worked out great, literally started first crank and ran smooth, idles a little low but I figure I just have to do some relearn procedures. No check engine lights.
I noticed that when I turned the engine off, and turned the key backwards, the battery light popped on, turn the key to where the fuel pump primes, and it goes off and stays off even with the engine running. But if your turn the key back, or even pull it out of the ignition, the battery light remains lit.
I checked battery voltage and it is slightly low, but resting @ 12.1 volts, with the car running its 14.2, so the alternator is working....
Has anyone ever heard of this before? Or does it point to anything? As far as I can tell everything is connected good and tight and in the correct spot, the ONLY thing I had to change wiring wise during this engine swap was I had to solder on a new alternator plug because I destroyed mine removing it. I simply went to the junkyard and cut the plug and pigtail off an older pathfinder with 3.3 (my cars a 3.5L), cut my plug off at the end, and solderred the 3 wires together. The wire colors were the same, and the physical plug was the same and clicked right into my alternator, and my solderring is perfect. Thats the only thing I can think of that would somehow cause this, at the light was not on before the swap, maybe the wires go to different pins on the alternator on the 3.3L? I shouldve confirmed that
Any suggestions where to start?
