Battery light on...
cimavip
Car: 1998 Nissan Cima VIP, 1995 Nissan Skyline Series II GTST M-Spec
Hello, I'm a newbie here...
I live in South Korea and own a 1998 Nissan Cima Vip Y33.
I have this car as a project for my self and have alot of problems...
Since ONLY 1 Y33 is aviliable in Korea it is very difficult to ask if i have any
problems and mechanics don't know about this car. So plz plz help me out..
My whole suspension needs to be replaced....meaning shocks,
bushings...etc. WHERE CAN I ORDER?? (willl ship out to korea).
My main problem is my battery light is on...
I checked my battery and it's 12.4 or 12.6V i think. Lit over 12V.
and i checked when car is running...it's 14.2~14.5. But if i unplug my
battery when car is on...engine stalls right away. If alternater is running
good it should not stall right away isn't it?
What should i do and how can i check the problem??
Also do u think old belt might cause this problem?
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
cimavip wrote:. If alternater is running
Thats completely wrong.. I think brian told me that... I have th 95, and thought the same, and unplugged the battery, and car went dead. So i thought it was the altenator, and so did tha shade tree mechanic i fired about 4-5 years ago.! Your car requires battery to stay running.. IN a lil bit, somoene is gonan come confirm what i said, but in technicall words !!
cimavip
Cool...thanks. Also can anyone tell me what is the proper voltage put out on Y33?
Q451990
Welcome to NICO!
What you're measuring sounds about right. A little over 12VDC with the car off, and about 14.4VDC running. Is your low battery light always on, or does it just come on sometimes? I have had intermittant alternator issues in the past.
It might be worth posting up a picture of the light in question... sometimes people will confuse the symbols on the dash. Years ago, we had a member swear his "differential light" was on - which doesn't exist. He finally posted a picture and we figured out it was the check engine light...
Typically Nissan products with a low voltage issue will also light up the emergency brake warning light and the ABS light...
Heath
cimavip
That battery light is always on.....HELP~!!
Modified by cimavip at 5:44 PM 2/25/2010
Q451990
No doubt that's a battery or charge light. The best I have to offer is a link to the US market Q45 of that same year. I have no idea how similar your RHD version compares to our LHD models. Check out this link to view the factory service manual.
To answer your other question, I don't know if http://www.infinitipartsusa.com ships internationally, but I suspect that if anyone does - they would.
Good luck!
Heath
