what wire are you talking about? i went to two autozones today and the battery and alternator still checked out great but the light is still on and all fuses are ok and wires are tight and grounds are goodthe converted wrote:Get a meter and check the voltage at the battery. The light is actually controlled by one of the wires on the smaller plug and I know that they went bad on my car so that would be something that I would check.
oh are you talkn abour the one you plug into the alternator?the converted wrote:There is a connector with two smaller wires that come off of the alternator.
That needs to be plugged in for it to charge normally, which traces to some connectors next to the battery. Those wires need to be connected.chinchilla wrote:
do you know whats the purpose of that plug?
i'll go ahead and check it out... thanks
