battery light on and on somedays battery light not on?
koukicrisp
problem with my 1991 240sx is that the battery light goes on and off...i have taken off the positive side of the battery while the car is running and it doesnt seem that it could be a bad alternator...do you guys think it could be that i dont drive the car everyday and the car sits 4 days to sometimes even a whole week but i start it once in awhile without driving the car?
the set up i have that i think can cause the problem on my car is:
the dual fan set up wired to a toggle switch so its always on and ac wired to a toggle switch
if you guys have any suggestions feel free to let me know
thanks in advance!
Vegascorbin
Car: 1990 240sx dirt track race car
Little tough to follw but if I am understanding you the Battery light on your car comes on when it should not.
If that is the case then yes the alternator is probably bad. When the car is running WITH THE LIGHT ON if you have less than 14 volt at the battery terminals then the alternator is bad. If you have over 14 volts then you have other problems.
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
Sounds like the alternator to me bud
GeneStarWindGSW
Car: 240Z, w202 C230, T1N, JK Wrangler, Mini Truck.
most likely the alternator. also could be a bad ground from the alternator or somewhere else.
r3v_v3ng3
Car: 91 fastback ka-t
loose alternator belt or if you put on a smaller (underdrive) pulley it will do the same
