battery light and e brake light
JOLTnPEST
hey i was driving home today in the rain and my battery and brake light on my Dash started flashing at the same time every once and a while. does anyone know what this means? i have a sr20 black top swap and a 1990 240sx if that helps any
thanksJosh
nrcooled
Car: cars, duh
sounds like a case of a bad ground. Go check your wiring. Every "problem" I have ever had with my swap has been the most retarded stuff, always an easy fix.
quiksilvia
Car: 95 s14 se
its electrical obviously, check all the connections by the ecu that had to be modded and the harness that goes into the cluster
MrFox
Battery and brake light together...99.999% its an alternator problem. Check output voltage. The 2 lights share an common ground.
sxse
Car: no more 240, '04 YZF-R6
make sure your brake fluid it past the sensor in teh resevoir?
that will make the brake light go on and off...
Touchdown038
Car: Computers, cars, sports
Yup, check grounds and alternator output. Watch for your battery light to go on every now and then also if it is the alternator.
