Can you guys elaborate on the hood sensor? If you leave your hood up, will it drain the battery? I've had some dead battery issues that were mostly my fault (leaving hatch/door open, headlights on when I park with turbo timer), but I've had a couple that I'm not sure why happened.Oh Em Zee wrote:Make sure the interior lights turn off after you close the door, unplug your hood sensor and inspect your wiring from the positive terminal to the starter motor.
