Battery keeps draining when parked, 2001 Infiniti I30
lamboguy
Hi Folks,
Just finished a search and couldn't find the answer, then saw this cool "IOM" forum so here goes:
I'm trying to track down a problem with my inlaw's 2001 Infiniti I-30
Great car, but it's simply dead every time they go out and try and start it. It's had several new batteries just this year. Dealer says they need to drive the car more. They drive it about once every 2 weeks.
here's the thing -- it has a draw of 180ma with everything turned off, key out, doors closed, etc. To me that seems to high -- comments? I did the same draw test on our lexus es300 and I get 20ma.
The draw is on fuse #13 (120ma) and fuse #12 (60ma). I have a print out from the dealer on what these fuses protect -- I'll dig it up, some of it I didn't understand but seems to be lights, interior lights, various memories (ac?) turn signals, etc.
So -- what should the draw be on this car? Does 180ma sound too high?
What should I look for to fix? I've checked for burned light bulbs...visors, doors, interior and trunk, tail lights, they are all fine. Seat memory is fine, seat motors work fine. I've heard possibly seat motors and stereo amps... how would I easily disconnect to test?
Also, where can I find a good manual with wiring diagrams? Dealer CD was $300 and seems overkill for this.
Lastly, can you recommend any good independent nissan/infiniti mechanics in the San Fernando Valley around Woodland Hills? (where the car is) Sort of "west of the 405" would be good.
Thanks, glad I found this forum, it looks good. And I'll search around for info later
Fred
PS: Also posted this in the I30 forum but no response
StarPD
Car: 2005 Q45
Not sure about current draw, but you might try removing fuses one at a time and seeing if the battery still runs down overnight with each one removed. When you find the one that stops the problem, you at least will know where to look further. Note that there may be fuses in several different locations, under the hood and under the dash, so go through them all. Check the owner's manual for locations.
