nismo528 »
https://forums.nicoclub.com/nismo528-u208816.html
Tue Aug 28, 2012 6:14 pm
XX7R has a good point, you may also want to check your ground wire, and any corrosion on the battery posts themselves. If the battery cables are rusty at the connection could also cause improper charging and the battery drain as it may not be charging enough while it is running for it to hold up over night or a couple days. I am just now learning about these cars, so I can't say of any known issues specific to these cars, but I had a similar issue with my old truck, turned out to be the battery cables were rusty at the connectors. good luck with it.
