bawllzdeep »
https://forums.nicoclub.com/bawllzdeep-u211688.html
Thu Feb 28, 2013 5:54 pm
Hi everyone,
I have a 2010 3.5 AC MT. This is the second time my stock battery has died on me and I was wondering if anyone else has experienced the same problem. Here are the details:
- About 5 weeks have passed since the battery last died
- I couldn't boost it right off the start. Instead, I had to connect all cables without either car running then turn on the car with the good battery for about 5 minutes and then my car started
- I drive my car approximately 15-20 minutes a day (sometimes a day might go by when I won't drive it at all)
- I live in Canada and the winter can be cold (between -40C and 0C)
- I tried to boost it again trying the same method and now it won't start
- I can hear a some kind of click when I push the start button
I figure something might be draining the battery but I have no idea what it could be or where to look. My dealership said the warranty on the battery is no longer valid (2 years) and they want to charge me $300 for a new one. I can just buy a cheap battery from Walmart for $100 but would you suggest that? If so, what type should I look for?
Any and every suggestion helps.
Thanks!
