Nigey »
https://forums.nicoclub.com/nigey-u308631.html
Mon Feb 06, 2023 4:30 am
Anyone had the same issue? I recently (don't know how) drained the 12V battery as fitted under the bonnet down to 5 volts. I believe this battery was replaced by the previous owner. I asked a Leaf Expert if there was a particular way to change it. I was told "no probs, disconnect the old and put a new un' straight in" I did so with a new Yuesa 54AH battery.
This is when the fun really started. On depressing the brake pedal and pressing the start button, all dashboard indicator lights came on and the warning KEY FAULT. I tried the spare key. Same message. I had the firm that supplied the car connect their diagnostic tool (a generic one for all EVs and not a specific Leaf one) He cancelled the 10 in number FAULT messages and the car started.
The guy who did the diagnostic check on his admission was not an expert and said he'd peruse it "further with the Experts" I await his results.
I have 2 questions:
1. Assuming the battery I took out was OK as its now, after charging, showing 12.7V, what caused it to go flat
2. What caused all the dashboard lights to come on and the KEY FAULT warning light to come up?
Thanks for reading my "epistle" and looking forward to an understandable cause and reason!
All good fun! Nigel
