dhennessey »
https://forums.nicoclub.com/dhennessey-u158010.html
Mon May 30, 2011 7:31 am
if you want to test it, try running around with the stereo volume fairly low. If the battery still drains, then there's either something wrong with your charging system, or the battery is dying.
assuming proper install, as long as the amp isn't drawing more amps than the alternator can supply you should be charging your battery easily. If your charging system is not functioning properly, a new battery will only mask the problem.
