Ilya »
https://forums.nicoclub.com/ilya-u159401.html
Tue Oct 03, 2017 7:43 pm
Welcome to the forum!
I would go to your local Sears or Walmart and buy whichever one fits your car (I have an M56x so unforunately I can't tell you the size - not sure if they are the same) that has the highest CCA rating (cold cranking amps). The higher the rating, the better the battery. I vaguely recall that most auto parts stores like Pep Boys or Autozone will even install the battery for you, but don't quote me on that.
I think I have a Sears Diehard battery (my car died in the parking lot right as I was leaving an alignment appointment lol - luckily).
If you are looking to replace it yourself, you can use the FAQ link in my signature to get access to the FSM (factory service manual) which should have the instruction on how to change it. You might need to reference the FWD section (which is basically the index).
