My battery cables are pretty messy, so, without consideration of the process up front I purchased a Z1 harness replacement!
Only THEN did I look more closely at the run of the harness and noted the negative lead bolted to the rear of the bell housing and, of course, a strain relief bracket with a 10mm bolt holding it right next to the negative lead bolt.
I dropped the starter which does provide a leetle more access, but just a pinch!
I suspect this is really just a matter of good pretzeling posture and lots of patience, but I wanted to ask if anyone has any tips to facilitate the process, beyond beer and tequila. And lots of patience!
Thanks in advance!
