Battery get drained / ticking sound from ECU HELP!!!!!!!!!!! 94 q45
Q45dude
Car: 94 Q45
Hello...
this is the second time it has happened. Car starts right away, I go and park somewhere for about 20 minutes or so, then I come back and I get no power at all, like there's no battery in the car. Then after a while, I see the security light blinking and the radio was coming on and off continously and I was hearing a ticking sound from the ECU. Car would not start. Called my friend to help me jump it, now I get full power but when I wanna start I hear tik tik tik tik, car won't start.
Can someone tell me what the heck is wrong?ECU? starter? battery??? Ground wire ???
THANKS SO MUCH...
hapaboi39
Car: 93 NISSAN 240SX COUPE
sounds like something is drawing too many amps... i had the same problem with my car and it was the starter drawing too many amps which caused a plethora of issues including the ticking/dead battery symptoms.
Q45dude
Car: 94 Q45
So , how would I diagnose what the problem is?
thanks
hapaboi39
You have to figure out what codes it's throwing then go from there.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Starter relay?
