joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Fri Dec 29, 2006 9:38 am
I see, well the amp can't bridge all 4 channels into 1, so I would use the front channels for your mid/high speakers. You'll like the sound quality over using the head deck internal amp.
The amp has a built in crossover, so you can use your deck's rear output. Make sure you turn of the deck's EQ, and flatten the curve. To connect the sub to the amp, you should see on the rear channel of the amp's speaker connection, an indicator of how to bridge the 2 channels to 1. Usually it uses the "+" from one channel and the "-" of the other.
To get the best possible sound, install 4-aftermarket speakers to replace the stock ones. Wire the left side together in series
Now for connecting the 4 speakers to the front inputs on the amp:
Wiring in parallel will draw the most current your amp can handle. Basically, you're going to wire the 2 right speakers to the amps front right output, and the 2 left speakers to the amps front left output. Really simple to do!
Start with one side, and wire the "+"s from each speaker to the "+" on the amps corresponding side. Same with the "-". Repeat with the other side.
I can send you a diagram if you like (you cant add attachments anymore on NICO )
