Slo_240sx »
https://forums.nicoclub.com/slo-240sx-u13690.html
Tue May 03, 2005 4:28 pm
Get a circuit breaker from your local parts store so youre not blowing 18 dollars fuses all day long. If you suspect a grounded alternator disconnect the battery then everything on the alternator without grounding the output wire on a ground somewhere. Then connect the battery back up if it pops then its not your alternator. If it still pops it may be some alt wiring grounded. Take your test light and see if you have power going to your output wire to your alternator. Its the one with the 10MM nut. that goes back to the battery from the alternator known as the "alternator output wire". That should have a constant power from the battery. If you do not have power there with the circuit breaker closed and output wire disconnected from the battery than you have an open wire.
Another thing to try to pinpoint a parasitic is to pull fuses one by one. Disconnect your battery and put 1 end of the test light on the battery post itself and the other on the battery cable. The light should light dimm for about 5 seconds. That is KAM (keep alive Memory) for your clock, ECU, etc... when the key is off. The light will go off after 10 seconds or so. If not you have a short. MAKE SURE DOORS ARE CLOSED! Your interior lights may kick on the test light! If the test light is lit you have a draw. Pull Fuses 1 by 1 and when the light goes out thats where your draw is. Look up a wiring diagram and inspect wiring on that circuit or any components on that circuit. Hope i didnt confuse you but diagnosis can be tedious.
Also, Look over ignition switch wires... Like if you put in a turbo timer, alarm, remote starter... They tend to blow the Master fuse if you've been in there and not taping or splicing wires correctly. Check wiring to your alternator and any other main components like the starter and such. It must be a big draw/short to blow the master fuse. Try that and get back with us.
-Alex
