Battery Drain?
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
Hey guys. I've been having a problem and I'm not quite sure what's going on. I mentioned a while back that the illuminated kick plates and door handles on my car no longer light up. Some suggested perhaps there was a blown fuse or damaged wires. I haven't checked it out yet, but I suspect that may be the case, because occasionally I notice that my car will hesitate a little when I'm starting the engine; almost like the battery is dying. Well, a couple weeks ago I couldn't start my car at all after a short drive from my house to the grocery store. I got a jump and it has been starting fine for the most part with the exception of the occasional hesitation. I took it to Auto Zone twice and they checked my battery, alternator and starter and all were fine. Could there be damaged wires that are causing a battery drain?
ibc
Car: Infiniti M56x
Take a look at this thread:
howto-disable-ecm-controlled-alternator-t623786.html
Are you taking many short trips these days? The ECM intentionally disables the alternator from charging your battery during short trips. It bit me. No more dead battery since I bypassed this stock Infiniti "feature".
Big_Tone
Interesting. Just about all of my trips are short these days. My office is a 5 minute drive from my house and the grocery store is even closer.
C6Joe1957
Car: 2012 Infiniti M56 Sport
2008 Infiniti G37 Journey Sport
ibc wrote:
Fri Oct 30, 2020 1:43 pm
Had the exact same problem after I bought my '12 M56S back in March of this year. My commute to work is exactly 8.1 miles and apparently, the alternator doesn't engage until after 8 miles. After the first couple a days driving to work and straight home, the battery drain finally caused my engine not to start. I had my battery load tested outside of the car and the charging system checked with both showing no issues.
Searched here and found the above referenced thread related to not charging and I performed the procedure outlined in this video https://www.youtube.com/watch?v=P9C5-OkxrJU&t=4s and never had the problem again.
Big_Tone
I just tried getting to the harness and couldn’t. It’s in the case to the left of the battery, correct?
C6Joe1957
Big_Tone wrote:
Sat Oct 31, 2020 10:59 am
You'll have to remove the battery access cover then remove the frame that the battery cover sits on. Remove the right side cowl and remove the battery if you haven't done so already.
EdBwoy's video on getting to the IPDM. https://www.youtube.com/watch?v=aoW_pp7XRiE
The IPDM is the box that sits to the left of the battery looking from the front of the car. Slide it out, remove the IPDM cover and you'll see the CAMBUS connector that has the yellow wire #76.
You will need a skinny, flat tool or a terminal removal key tool if you have one to slide into the yellow wires terminal to release the yellow wire's connector.
https://www.amazon.com/dp/B07T6972Z4/re ... NrPXRydWU=
Wish now that I had taken photos but to the best of my memory, that's how I removed it. After removing the wire connector, I place a skinny 1-inch length of heat shrink to shield it from grounding on anything and tucked it away.
Big_Tone
C6Joe1957 wrote:
Sat Oct 31, 2020 3:33 pm
Got it. Thanks! I'll do this tomorrow.
Ilya
Yeah. Also had battery issues until I did that 'life hack' and got a new AGM battery. Been fine since.
Big_Tone
So, in my car the wire in the same location as what’s illustrated in the YouTube video isn’t yellow, it’s blue. And disconnecting it disables whatever it is that unlocks the steering wheel and recognizes the key. There is a yellow wire in that harness, but it’s in a different location. Is that still what I need to disconnect?
Ilya
Not sure why your wire is different but here are some pics:
howto-disable-ecm-controlled-alternator ... l#p6800881
Big_Tone
Ilya wrote:
Mon Nov 02, 2020 9:21 pm
Thanks! I saw comments about a yellow wire and got really confused. I'll try this one this weekend.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
So gents what's the consensus on this mod? Is it worth doing? Do you guys feel like it helped? It may be in my head, but I feel like I've seen/read mixed reviews
madmanpauly
Car: 2011 Infiniti M56S
I had lots of issues prior to the mod and then zero issues since the mod. It took me 30 minutes to complete and didn't hurt anything. Very little risk for a big reward.
Ilya
I had issues after the mod still but I think it was a crappy battery that was jussttttt strong enough to pass tests. Alarm would go off randomly, etc. After getting a nice new AGM and doing the mod, no random alarms, no issues starting, etc. So I can't say for 100% certain that the mod is critical too do but it just seems like a no brainer.
EdBwoy
DoN_BLaZe34 wrote:
Wed Nov 04, 2020 11:43 am
If ever there was consensus, I would say it is "Yes, do the mod."
I have seen a lot of positive reviews, some neutral, and no negative reviews so far.
On neutral, Ilya comes to mind as some time back I saw a post about the mod not improving his symptoms.
So, for the overly cautious, I suppose it wouldn't be a bad thing to do. There are no negative reports yet, and although you lose the few benefits of an ECU-controlled alternator, most posters didn't seem to mind or care for that.
By forum reports, it seems to affect the earlier year V8s more than others.
As for me, I do not plan on doing it. I have owned & operated a few M56s and none of them have exhibited any symptoms, even when abused and kept under the oft-quoted 8 mile threshold.
If it ever affects me, I'll reconsider.
DoN_BLaZe34
2006 FX45 - Traded
Thank you all for the responses. I will look into this.
Big_Tone
So, I did the mod today and removed the correct wire. I'll post my experience goo/bad/indifferent. Thanks guys!
biggie
I haven't had this issue with my old M56 or so far on my Q70L. But wife's QX56 has this problem, I've really got to find out which wire it is on her ride.
Big_Tone
Big_Tone wrote:
Sat Nov 07, 2020 1:22 pm
So, I did the mod today and removed the correct wire. I'll post my experience good/bad/indifferent. Thanks guys!
Jap Burd
Car: ‘95 Q45
You can check it in the fuse box w/ a meter.
