rsjoyner »
https://forums.nicoclub.com/rsjoyner-u235509.html
Mon May 05, 2014 2:44 pm
Thanks for responding. The car is completely stock. Found a relay under the drivers side dash where the viper box was. As far as I know, all of the wiring for the viper has been removed. It was a professional installation and was fairly easy to remove. (except for laying on my back, upside down with my feet on the headrest and my head on the brake pedal, still feeling it in my neck.) The 5 speed, motor swap, lowering, etc will come later if my son decides to keep the car. He is 6'-1" and 240 lbs so its kind of a tight squeeze. The battery drains over night unless I unhook the negative terminal, then its fine. I have an inspection camera and I stuck it in the door panel and watched the lock actuator as my son reconnected the battery. The cover on the actuator is clear and I could see a tiny lever engaging as he did it. The H/L ret down relay also clicks occasionally when doing this. Not to be long winded but one other thing. When my sister in law had the car the headlights did that thing that the nissans do. One light would not come up/go down. My father in law, being the resourceful fella he is, wired straight from the drivers side headlight to the passenger side and the problem was solved. Could that be causing some kind of drain. If it was me I would have replaced the headlight switch like I had to do in the 2 300zx's I had. Any ideas would be helpful and appreciated. Thanks
