ghettoslide »
https://forums.nicoclub.com/ghettoslide-u18248.html
Mon Jul 19, 2004 4:06 am
check voltage regulator, may be a part of the alternator. I have not had this problem with my 240, but did with a '79 impala. This was the problem, otherwise some dvoms can capture parasitic draw and tell you which circuit it is on, make sure nothing in your car still has power when ignition is off, Make sure the top of the battery it self is clean of dirt and liquid,belive it or not this can draw voltage from a battery, I'll check all data and tell you where that white wire goes.
