battery drain problem /negative battery cable
ricebike
2002 Quest
2005 Altima
a dude messaged me last night thru yahoo messenger...
he's got a 92-93 240sx... wanted to know where the negative cable is attached to in the engine or the frame?He has tested his alternator/battery & both were good.He also has returned to Walmart to get a replacement battery under warranty ~2x already.
I've got an 89 so i can't help him much, plus I don't even own a multimeter & is hesitant on working on electrical; any of u DOHC guys check & post your findings here?
I'm attaching a thread that i've found that's remotely close to this...http://www.nissaninfiniticlub....drain
Yellowjacket, is this the same way to hook up an ammeter to test for excess parasitic load? I'm guessing to hook it up in "series" then pull/replace a fuse 1 a time until the amps drop to near zero= find the circuit in ?
his email is [email protected], but i'll refer him to this thread as well..
thanx in advance:ylsuper
yellow_jacket
Car: 95 240sx
Yep, same thing. Just most people don't have a multimeter so using the test light is an alternate way of doing it. Not nearly as accurate or good though.
ricebike
2002 Quest
2005 Altima
k, soo my guesses are getting better... :ylsuper
did any KA24DE guys follow the - battery cable from the post to ???
trpower7
You can ground the battery anywhere on the frame. Buy a ground strap, drill a hole, thread it for a bolt and ground that sucker down.
