dillonm695 »
https://forums.nicoclub.com/dillonm695-u13665.html
Thu Feb 19, 2004 4:15 am
Good Morning Shipmates,
New to this site - looks like a great place!
Problem: 1996 Infiniti I30, completely stock, 5spd transmission, 135k miles. Battery drain is ~115 mA with key out of ignition. This seems to me to be about 100 mA to high. I pulled some fusible links and fuses, testing for current draw, and found that there is about 30 mA across the fusible link 'power window' and a 52 mA drain on the fuse 'BCM' (aka body control module). I'm using a cheapo $2.99 meter from Harbor Freight.
Has anyone diagnosed and fixed a current drain problem with the BCM or the power windows?
Thanks,Max
