steve s14 »
https://forums.nicoclub.com/steve-s14-u23089.html
Tue Feb 17, 2009 3:25 pm
Turn off everything in the car and remove the key from the ignition, make sure that the doors are all closed and the dome light is off.Remove the negative battery cable and hook up a test light to it by clipping the wire lead to the negative cable and the other end to the negative battery terminal. If it lights up, you have a parasitic draw.At that point you have to figure out which circuit has the draw.The easiest way to do this is to remove a fuse and see if the light goes out and reinstall it if it stays on one at a time while the above conditions are met until you find the one that makes the light go out.Once you found which circuit it is, then you need to see what that circuit powers and go to each component and disconnect it to see if that removes the draw. Usually it's aftermarket items like alarms or radio and things that usually causes parasitic draws so i would recommend checking those items first.Good luck!
