you can also roll them down by turning them to the right, and by holding down the unlock button on the keyfobjohnnir3volution wrote:Did you know you can roll up your windows from out side by simply putting the key in the hole and holding/twisting it to the left?
i believe its part of the pre-install program code on your factory code.blahblahblahblah wrote:Holy cow guys, that actually worked. Im suprised at how easy that was... thanks!!
Any idea why that worked and why it doest that?
devilmagic wrote:know How to roll up the window with your key fob? Instead of turning the key ?
you can. But you have to buy a module or something. you can get it to roll up from the key fob, you can even get the sun roof to open with the key fob. you have to buy some module though.Blackmobile wrote:can't
I also remember that. They also sold a module that would tilt the side mirrors down when the car was put in reverse. IIRC it was pretty expensive for such a simple feature though.Hussain wrote:devilmagic wrote:know How to roll up the window with your key fob? Instead of turning the key ?you can. But you have to buy a module or something. you can get it to roll up from the key fob, you can even get the sun roof to open with the key fob. you have to buy some module though.Blackmobile wrote:can't
I remember from like 2008 or maybe 2009... forgot the info but someone posted a youtube video showing it back then so maybe its still on youtube and they'd have more info
DJBeasy wrote:^That is ridiculous, I would go back there just to tell them off.
Welcome to the forum, lots of useful info here.
EDIT: And kudos on using the search function!
