JT_MONEY_2004 »
https://forums.nicoclub.com/jt-money-2004-u17668.html
Mon Aug 02, 2004 9:54 am
That's part of what i was saying or intended to say, the door could definately be the problem, it was mine. When you close all openings(not including windows) your security light should not flash, it will stay "on" then go out after a few seconds (not exactly sure how much). Here's what you do, remove the duct tape you have now.close doors, leave driver's window down so you can see in clearlyif security light flashes after you LOCK IT W/ KEY. If it's flashing lean on it and see if the light stays "ON". If it does, there's your problem. (if it continues to flash, another opening has the problem)Now you can either order new rubber covers from nissan to replace the busted ones, or try my trick. You'll need to use epoxy, it'll stand up to very high temps, hotter than the climate will ever get. **BUT** before you apply epoxy use some tape to temporarily place it, make sure what you're gonna use will work (i.e not too big or something and that door closes flush)***Make sure to take your time placing it one you put epoxy on it , make sure it'll make good contact w/ the door sensor. Let it set for a 10mins, close door and keep it closed for a few hrs.Jump car, let it run or take for a 20min drive, your battery should be charged by then, if you still have dead battery issues, alternator and/or battery will need replacement.
Dont forget to check battery terminals are clean and have a good connection.
