Battery Cutoff Switch
gomer23
Car: 1989 Nissan 240sx
Since I figure most RB guys relocated their batteries to the rear...where did you guys put a cut off switch to run at drag strips or other sanctioned racing events?
krayton
well if thats what your worried about, then check with your local events to what you need to do.
in AZ our track events (for the lower racing class) dont require anything. but our drag strip here says you need it outside the car
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I put a kill switch in my hatch on the ground to the battery. Ill post pics up of it sometime later when i get time.
gomer23
Well ya our one gay 1/8 track (our 1/4 closed and the closest one is 3 hours away) requires a switch out the outside of the car. I was gonna put it behind the plate but the way the bump is I cant get teh switch in there. I could do it under the car a little bit but I think it has to be in the back of the car somewhere. So I was curious where people put theirs (if anyone uses them).
kjlindgr
Just be careful about where you place the cutoff switch. You usually can't hide them too well because that defeats the purpose of the switch. The track officials need to be able to find them quickly in the event of an accident. They are dumb to look at so I can appreciate your desire to want to put it under the car a little but if you don't pass tech, then it was pointless anyway. Just a thought.
Here's a picture of the cutoff button/switch on my car.
Shocker
Car: 89 240sxHB rb26/30
kjlindgr wrote:Just be careful about where you place the cutoff switch. You usually can't hide them too well because that defeats the purpose of the switch. The track officials need to be able to find them quickly in the event of an accident. They are dumb to look at so I can appreciate your desire to want to put it under the car a little but if you don't pass tech, then it was pointless anyway. Just a thought.
more pics pls.. looks ill from behind!
Eikon
Car: 71 240z, 93 Supra TT
meh... seen one you've seen them all..
LOL.. Yeah Karl.. more pics!!!
Pics or
gomer23
I guess more or less I dont care around looks more of people messing with it but I supposed I could just run the switch at the track and daily driving bypass the switch. Thanks for the help so far.
