onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Sep 20, 2005 7:11 pm
And obviously the ppl who didn't know about it probably have never gone to an SCCA, NHRA, or other sanctioned event where a cutoff is required for remote mounted batteries... it's not just for drag racing ppl... .
Anyway, the battery is only needed for starting most of the time. The reason your car is still running, as you already know, is that the devices in your car are hooked up directly to your alternator.
Your Current Setup:
Here is ONE proposed solution, but there are probably far better ones.
If you want to keep the switch there, you will need to run another separate wire, isolating the alternator & the rest of your electronics.
Possible Future Setup:
To figure out which of the terminals you need to connect to, you will need to use a multimeter in the ohm testing to test for continuity.
Have it in "ON", check each terminal against the others. Then do the same for "OFF". After that, you know what connects to what, and what will be disconnected to what.
If you don't want to do that, technically, you can just run the alternator wire directly to the battery & the electronics on the other side of the cut-off switch. This will disconnect all electronics from any source of power, which in turn will turn off the car. Of course, you probably want a circuit breaker or two somewhere in these stream of lines.
Hope that helps!
Modified by brokeAs240sx at 9:34 AM 9/22/2005
