dougan17 »
https://forums.nicoclub.com/dougan17-u99539.html
Fri Jun 20, 2008 4:42 am
alright well I've had this problem with my car for well over a year now and it has given me all sorts of headaches. Basically any time the car sits for a lengthy period of time (say, 16 hours) the battery dies because there's a constant drain on it. I just have to recharge the battery and then give the relays a tap to release something and she starts back up but it's a pain in the you know what. It's an SR20det rwd red top and I'm not sure if this is a typical problem or what. We've replaced every relay, had four different mechanics look at it and nobody seems to be able to find the problem. I understand this is a bit of an asinine question given the huge amount of things that could be causing it but I'm really stuck. Failing an answer, does anyone know of anybody with extensive experience working with these engines in the MA/RI area?
thanks a ton
