DLK wrote:Well my car is five years old (bought it used) and I have had it for 2 years. It does appear to be the original battery. So more questions:
Can I use a regular battery tender (i.e. my Battery Tender Jr.) to keep all my presets?
=>A 12VDC Battery Tender with at least 1 Amp capacity, provided all car electrical loads are off, should be sufficient. Older cars have parasitic drain of @ 50mA but the M will have much higher than that (I have not take any measurement yet).
Has anyone used a 24F successfully on a 2006? Aren't all 24F batteries the same size? If one fits, shouldn't they all fit?
=>Car batteries conform with BCI specs so 24F dimensions should be the same regardless of brand. I believe that 24F will fit in but it's your responsibility to verify that. Note that the 24F is 1.125" taller than 34R so you have to make sure that the battery cover can be closed AND the battery clamps/bracket have enough threads to accommodate the taller battery.
How do you remove the passenger side trim that everyone keeps talking about which gives them a hard time?
=>Clips are used everywhere. You have to remove the pax side cover (clips underneath), then BATT cover followed by BATT lining (5 clips). Then remove the rubber trim halfway to expose the split on W/S plastic trim. Remove 2 plastic clips, then the plastic trim below pax side W/S (AC air intake) only. Disconnect battery cables and remove the BATT bracket (2 nuts). Remove battery and clean the connectors. Battery installation is just the reverse. Note that the rear clamp/bracket is hooked to the firewall.
I'm not sure paying double is worth it for the DieHard Platinum, especially since the other batteries have a 3 year free replacement period and a 100 month warranty (at least the Duralast does.)
=>As always, you are the owner...your call. I've used OEM as well as batteries from Costco with no problem.
According to Consumer Reports, all of the Group 35 batteries were well below 700 CCA, usually around 650 or so. I don't think this is acceptable since the OEM stat is 720 CCA.
=>Batteries within the same group can have different CCAs so you have to check if the battery you are looking for meets or exceeds the spec. And you are right, Group 35 (shorter) batteries in general have lower CCAs than 24F and 34R.
I am a little confused about the "reversed polarity" issue. I though the issue is that the positive terminal is on the right. I don't see how you could fry anything if the correct terminal is hooked up. Polarity is polarity. Positive is positive. If you get the wrong battery, you should not be able to connect it because the red battery terminal will be on the left, and the Infiniti positive cable is on the right, correct?
=>The problem is that some people have no clue about polarity or simply not paying attention. As installed, 34R battery pole on RH side is positive. A Group 34 battery has the same dimensions but has reversed polarity as installed. And there is no way that you can connect them correctly due to short battery cables. So if someone accidentally connected a 34...it will be an expensive learning experience. And it already happened to a forum member so I hope that will be the LAST.
IlyaKol wrote:Has no one on this forum heard of Optima batteries? Many members on Maxima.org use the Optima Red or Yellow top and swear by them. I had one in my Maxima and it was great.
had both a red and yellow top in my Millenia with no issues..IlyaKol wrote:Has no one on this forum heard of Optima batteries? Many members on Maxima.org use the Optima Red or Yellow top and swear by them. I had one in my Maxima and it was great.
I had my battery changed by a local mechanic with no battery tender, and did not lose my XM either. I didn't re-read this entire thread, but I think I have read it or some other similar thread before, and if I remember correctly, the XM loss tends to come with extended battery disconnection, not a quick battery changeout disconnection.DLK wrote:I was correct that my Battery Tender Jr. was not supplying power for lack of a circuit. I supposed if I had connected it to the negative cable it would have worked, but that is not what the instructions say to do, since it is a smart charger. But all I lost were my radio presets and my seat memory. Oh and the trip-ometer seems to have been reset, oddly enough. XM still worked (but had to reset preset stations), so the person who lost their signal maybe had other issues going on.
Mine was actually disconnected for almost a whole day....still came back no problem.The00Dustin wrote:I had my battery changed by a local mechanic with no battery tender, and did not lose my XM either. I didn't re-read this entire thread, but I think I have read it or some other similar thread before, and if I remember correctly, the XM loss tends to come with extended battery disconnection, not a quick battery changeout disconnection.DLK wrote:I was correct that my Battery Tender Jr. was not supplying power for lack of a circuit. I supposed if I had connected it to the negative cable it would have worked, but that is not what the instructions say to do, since it is a smart charger. But all I lost were my radio presets and my seat memory. Oh and the trip-ometer seems to have been reset, oddly enough. XM still worked (but had to reset preset stations), so the person who lost their signal maybe had other issues going on.
/\06M4.5 wrote:I got a Sears Gold battery a few days ago.
and yes the red top optima battery is not what they used to be.
I also had 2 red tops in my 97 Maxima
If I'm not mistaken, doesn't the M require 720 CCA ??? Again, I am looking for a deep cycle battery if possible. It's not a necessity, more like a want. I just don't want summer to come around and I have all of my electronics running with the AC on and lights. Don't wanna stress out my electrical system06M4.5 wrote:some info on sears gold:
Group Size 24F
700 CCA (cold cranking amps)
120 minutes RC (reserve capacity)
36-month free replacement limited warranty*
100-month pro-rated limited warranty*
Maintenance free automotive battery
Carrying handle
Flush manifold vented cover
Application code B-11
Meets OE requirements for many automotive passenger car and truck vehicle makes such as Toyota, Honda, Acura, Nissan, Mazda, Infiniti, Mitsubishi and others
