CRyan »
https://forums.nicoclub.com/cryan-u23575.html
Tue Jan 27, 2009 9:19 am
Well - I've finally gotten my car back on the road. I replaced all belts, rear rotors, bearings, and pads, along with the battery.
And I still am having the same issue as before. The battery will not charge, or alternator do its duty.
Now before I get under the vehicle to take out the alternator to get it re-conditioned, I wanted to run it by you all on what else it could possibly be.
I checked the fuse (as which I THOUGHT was the fuse, it stated it was ALT S) and it looked fine, but just in case, swapped it with my A/C fuse which is also a 7.5.
Still waiting on the battery to charge - I guess next would be to check over with a volt/ohm meter, but I'm not entirely sure where I need to be checking. Just on the battery? To see if it builds a charge at X rpm?
Or somewhere on the alternator?
Also have an issue with the horn - after my little fender bender (nothing major) my air bag light came on and now flashes and horn doesn't work. Checked the fuse, It looked fine - think the horn is just played out - I believe it is still OE horn.
