Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Thu Sep 09, 2004 11:42 pm
Right now I'm using a 12v 10amp Carquest automatic charger ($60). I let it charge last night for 13 hours. I went out to remove the charger and start the car, and it was still low on power and had a hard time starting (interior lights were dim, etc). It will start with the charger attached and turned on, however.
Just now I removed the battery terminals and charged it directly; I'm assuming maybe something like the clock (?) is slowly removing the same power that is being charged to the battery.
Is there a higher-capacity charger I should be using instead?
The battery is an Everstart 750ca DT-3N, which is about a week old. Is it possible the battery was drained so much because of the bad alternator that it now cannot be fully recharged? The behavior is like that of a bad battery -- it takes a few tries and it barely cranks but it finally does start.
[And of course the alternator is bad, thus the purchase of a charger to get by until repairs are done.]
Thank you!
-Jesda
