Julio Bro! »
https://forums.nicoclub.com/julio-bro-u378.html
Fri Dec 05, 2003 1:57 pm
Alright Nistech and 180fan, I did some checking on the nature of the OEM cable and you're right, it includes the sub-harness. I also checked the Monster Cable stuff and it's pretty good, particularly the battery terminals, and I think it's priced OK.
I just installed the highest amperage Interstate battery I could get (any opinions on this brand?); strange fact is that it is smaller than the regular models, because of this the unit comes with an adapter for the OEM bracket. Cost me $80 with a 14 month full warranty and up to 5 years, $1.55/month differential.
Because my old battery was leaking, the replacement terminals began to corrode (some of this travels farther inside the cable), right now is working fine but I suppose it could be better. I'm thinking checking out the sub-harness, if it's truly independent from the thicker cable, I'll probably get the hardware from Monster and prepare a new one. Regarding the negative cable, it does have this crimped "tap" to the battery tray and Monster doesn't have this "side ring" so I don't know how I could make for that. That would go for approx. $120 without the new sub-harness.
On the other hand for $130 I would be getting a brand new set including the sub-harness. I know it won't be the same power transfer as with Monster, but hey it's new cable and connectors, the old ones have been there for 10 years.
Or, I could just leave all the cables there and just replace the battery side terminals for $60 Monster connections.
What do you think?
