steeda763 »
https://forums.nicoclub.com/steeda763-u44310.html
Wed Feb 18, 2009 12:18 pm
You must run a minimum of 4-GA to your starter, so if you use a heavier gauge (i.e. 2-GA) you will be just fine.
I think those tool-less terminals are overkill, to be honest. You can buy a 200a circuit breaker -- like those used in car audio -- and place it in line between the positive terminal of the battery and everything else. If you want an easy disconnect all you do is press the red Test button.
Of course, these are my recommendations because I, in fact, use 4-GA cable with a 200a circuit breaker.
